PXI
PCIe-8398 compatibility with motherboard
Hi people.
I have a motheboard with one PXI-E x16 Gen 3 slot.
But I didn't find any information about compatiblity of this device with motherboards. 😞
I know about NI Compatibility Software. But it requires to have a physical board.
My goal is to be 100% sure that selected device for PXI Remote Control will be compatible with my motheboard. 😊
A there list of compatible motherboards and BIOS versions for PCIe-8398?
My motherboard is ASUS PRIME H510-M-K;
(1,028 Views)
@alex_whiteknife wrote:
Hi people.
Unfortunately, No. There are literally thousands of motherboard models across a few hundred different manufacturers, NI could not practically buy and test every single one (btw there might be a new motherboard introduced every day somewhere in the world).'
As a side note, BIOS is developed specifically for a motherboard(s) and chipset(s) combination, hence it is not universally comparable with just version (like a tailored shirt)
All that you can verify is whether the motherboard has the PCIe slot required by PCIe-8398.
An easy option to avoid all these uncertainties is to get a PXIe embedded controller (this is for sure 100% tested by NI and compatible with the chassis).
Santhosh
Soliton Technologies
(1,008 Views)
