PXI
PCIe-8381 not booting Motherboards compatible(?)
My current motherboard is not compatible with MXI daisy chain architecture, that's why it is not booting up using the PCIe-8381. None of the manufacturers provide information about that spec (daisy chain on PCIe ports) which is a recommendation from NI, does anyone know a model or list with tested motherboards that can work along with the PCIe-8381 for a remote controller?
(1,091 Views)
Generally, NI does not publish a list of such motherboards, same goes with Thunderbolt 3 based remote control support too.
A safer and more reliable option is to go with a PXI controller but that would be an expensive path too.
Santhosh
Soliton Technologies
(1,075 Views)
Hi Romell,
Have you tried the BIOS compatibility software (along with setting the DIP switch on the PCIe-8381)?
MXI-Express Products and MXI-Express BIOS Compatibility Software Compatibility - NI
If you have a PC where the PXIe-8381 shows up you should try the latest firmware. It helps with compatibility in some systems.
PXIe-8381 Firmware and Additional Drivers Download - NI
- Robert
(1,056 Views)
