12-16-2005 08:28 PM
12-19-2005 12:21 PM
Greetings!
1) Are you using a PXI system which has an embedded controller
with Real Time (RT)?
2) Did controller have RT installed / shipped with it. We can
confirm that in the bios if the LabVIEW RT menu options show up?
3) Listed below are few links you can go through to get started
and troubleshoot. Specifically the chapter 2 in the manual for 8184
http://www.ni.com/pdf/manuals/370836b.pdf
http://digital.ni.com/public.nsf/websearch/A43DD6F680D123DD86256F870002B6A2?OpenDocument
http://www.ni.com/support/install/install_hardware_5.htm
4) When you connect a monitor to the controller what do you see in
the screen?
5) Did you get a chance to install the embedded sw CD that came
with the controller in your host computer?
6) You can also verify if you have a folder similar to following
in your host computer after the installation (Similar to the following)
C:\Program Files\National
Instruments\RT Images\Base\2.0\7151
Thanks and hope this helps to get you rolling
Good luck
Avi Harjani
12-23-2005 12:28 AM
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
