This is probably too late to help you, but in the Process Model's "TestReport"
sequence calls "ModifyReportHeader" in your file. Is that what you were
looking for? (At least, it's that way in 1.01, I assume 1.02 is similar.)
Michael Pollack wrote:
>have all details right, but here goes...We are using
>teststand v1.02 (lastest version IIRC) at work to run a series of tests
>based on the Test Stand Model sequence file. The only sequence being
>modified is MainSequence.
>At the top of the generated report (header) shows info such as serial
>number, execution time (IIRC), etc. The last item is the UUT status
>(passed/failed). Where is this item generated/added in the report (I
>would believe in the ReportHeader callback??). I need to modify
it.
>Thanks.
>Michael
>michael.pollack@honeywell.com>
