precise time of wait function
Hi everyone,
I want to use a wait function in a program of TS between 2 steps with a precision of 1ms.
Wait function gives me each time diffrent time. For example I set it 2 seconds but it is not precise. the time taht I measure using Second function are 2.03, 2.06 , ...
It means I have a deviation each time in a range of 300 - 500 ms.
Is there any solution to make a presice time in TS?
Thank you so much for your help.
(599 Views)
You can never expect high timing precision on Windows. Windows is a general-purpose operating system. Any other program or background process will compete for the CPU resource and impact the timing precision.
Try to close all programs and run only TestStand.
Control Lead | Intelline Inc
(577 Views)
Okay. Thank you @ZYOng for your reply.
(560 Views)
