11-23-2022 03:36 AM - edited 11-23-2022 03:40 AM
Hi everyone,
I need to read an analog value from an output continuously and in other steps this value will be used. So it is important to read the value continuously.
Is it possible to run the step that read the analog value, separately and always? I wanted this step and reading the analog value to run as seperate thread everytime Like multithreading in other programming languages.
Thanks for advanced for your help.
Solved! Go to Solution.
11-23-2022 05:36 PM
You can call a sequence in a new thread or use step type to run a vi asynchronously.
11-24-2022 07:44 AM
Thank you so much for your reply. It works.
