03-12-2013 10:48 AM
In my LabView user interface, I want to open a sequencefile which name is in a string.
With NI user interface, it is done with a connection between SequenceFileViewMgr and a button. In execution, when I push this button, it open a dialog box. Is there a way to disable this dialog box and to select the sequencefile from another way.
Second metod, I intend to open the SequenceFile from the Engine with the GetSequenceFileEx Method. But with this method, it seems to me that I can't use other connections to lauch, close ... sequenceFile. So I will have to write code for all these actions, which could be quite long
So, What is the right way ?
Laurent
03-13-2013 09:41 AM
Use a regular labview button (no connections) and add code to it which calls ApplicationMgr.OpenSequenceFile. See the API help for more details.
Hope this helps,
-Doug
