When using property loader steps to import property values from a database is there a built in function to dynamically load different versions of properties during execution?
I was looking for a way to select specific property versions using the NAME column in my database group table. It appears that the filter function only works with the properties table and does not allow for the use of variables. Is there a way to dynamically select the version of properties a sequence uses during execution? Or will I have to resort to the use of multiple property loader steps with select statements.
If this is not the intended purpose of the group table, how is the group table supposed to be used.
Thanks, Sungjoon
