04-09-2024 06:45 AM
I have an Keysight DMM 3458 connected with GPIB - Ethernet converter and configured into max. I use the DMM with other software this way and it works fine. We are looking at moving to TestStand 2014 as our test langue but I can't seem to get TestStand to see the DMM. I have read many post here and on the web but I can not figure it it out.
04-09-2024 06:51 AM
TestStand 2014? Typo?
Are you intending to talk to the instrument directly from TestStand, am I understanding this correctly?
04-09-2024 11:26 AM
I have both 2014 & 2019 installed, and yes trying to talk to the DMM directly, set the function and get the reading.
04-09-2024 12:26 PM
What test language?
04-09-2024 01:38 PM
The intent was to do it all in TestStand but after reading some other posts it doesn't sound possible. If I need to write DLL's of some other wrappers it would be in C#.
04-09-2024 03:33 PM
TestStand is a sequencer and not a programming language. Some custom steps implemented in "a" programming language make it simple to interact with instruments.
List of supported adapters - https://www.ni.com/docs/en-US/bundle/teststand/page/adapter-and-code-module-support-for-64-bit-te.ht...
In the same way, if your instruments come with drivers in "a" programming language supported by TestStand, you can directly use them in TestStand.
04-10-2024 12:36 AM
In your case, you might also be able to use an IVI step type
According to ni.com/idnet your particular instrument has IVI support.
Having mentioned this for the sake of completness.... it is strongly recommended to perform instrument IO using code modules. There may be execeptions...
04-10-2024 12:37 AM
Don't start with 2014, go for 2019 instead!
04-11-2024 05:10 AM
Thanks for all the information, I re-wrote one of our drivers that we use for Keysight VEE into a C# DLL that seems to work for what I'm looking to do.
