I have been developing DLL's using CVI for use with GPIB instruments and NI PCI cards. I am at the moment trying to create a utility function within a DLL using a CVI dialog box, but have been having a few problems. The code compiles up ok but when I try to execute the code within Teststand I get the following error message, "The callback function, GraphicPopup, specified in the UIR file, is not a known function. If you are using an external compiler, you must include the UIR callbacks object or source code in the executable or DLL."
The GUI panel header is included in compile list so I don't understand why it doesn't recognise the function name.
Can anyone help?
Mr F
rancis Murphy
Edinburgh
Scotland
