04-01-2019 02:31 PM - edited 04-01-2019 02:57 PM
This post implies that Tools >> Update Sequence Files will update the Types
https://forums.ni.com/t5/NI-TestStand/Update-All-Sequence-files-automatically-Types/td-p/2319322
But yet another post claims it does not.
https://forums.ni.com/t5/NI-TestStand/How-to-mass-compile-types-after-Labview-update/td-p/3822095
I have tried the Update Sequence Files tool for the explicit purpose of updating my sequence files to the latest process model / engine type definitions and have found that the types remain unchanged. In particular the Type that needed updating was NI_ModelPlugin (Update needed because changing from TS 2016 SP1 to TS 2017)
Can anyone confirm if the Update Sequence Files tool is supposed to update Types?
04-03-2019 10:19 AM
I do not see anything that specifies that tool for updating types. The help menu states that the "Sequence File Converter", which opens when you go to Tools >> Update Sequence Files is used to resave sequence files and it can be used to ensure that a group of files are updated so they load as quickly as possible.
Here is some information about the tool:
http://zone.ni.com/reference/en-XX/help/370052N-01/tsref/infotopics/sequence_file_converter/
04-03-2019 11:26 AM
Thanks for your input. I found that the Diff and Merge Utility will update Type definitions if option "Automatically Merge Types" is enabled. I have experimented and this appears to upgrade the sequence files as desired.
