NI TestStand
Teststand 2017 wont launch
Hi
I can't start Teststand 2017 SP1 32 bit.
NI Package manager lists it as installed.
Teststand version selector does not list it as installed.
I've tried uninstalling and reinstalling but every time I start it gives an error.
"A problem has caused this program to stop working correctly. Please close the program."
Pleas help resolve this
Other version of Teststand open without any issue.
(636 Views)
It might be because some old packages associated with TS 2017 was not uninstalled correctly.
One thing to try - review the following KB for names of packages and remove or ensure that all packages associated with TS 2017 are removed and reinstall TS 2017 again.
TestStand 2019 and Later Crashes on Startup After Upgrade - National Instruments (ni.com)
Anand Jain
NI
(628 Views)
