We have been using Rational Software's 'Purify' Product to
try and identify memory leaks in our test software but have
experienced problems with some of the TestStand DLLs.
Problem seems to occur when the TestStand Sequence Editor tries to login
Error Message obtained are
Error Popup
Unable to load test environment adapter 'C/CVI Std Prototype Adapter'.
Run setup to re-install or remove this adapter
Could not load test adapter DLL 'c:\apps\teststand\Bin\SCVIAdp.dll'.
Error Code - 17004, Could not load DLL or library.
Run-Time Error Popup
An error occurred in the 'Login' step of the 'LoginLogout' sequence in 'FrontEndCallbacks.Seq'.
Could not load DLL or external library 'c:\APPS\TestStand\
Components\NI\Callbacks\FrontEnd\frontend.dll'.
Could not load DLL or library. Error Code: -17004
Error Popup
An Error occurred while running the Front End callback 'LoginLogout'
Could not load DLL or external library 'c:\APPS\TestStand\Components\NI\Callbacks\FrontEnd\frontend.dll
Error Code: 17004, Could not load DLL or library
Would appreciate help on the following in the following areas
· Has anybody used TestStand with purify, if so have they had similar problems
· Has anybody used a similar tool such as 'BoundsChecker' with TestStand
did
you experience any problems
· Can anybody think of any reason why these dlls shouldn't work with such
a
tool
Note
. We are using TestStand 1.0 and MSVC 5.0 and purify 6.0.1
. We have also experienced problesm with the cvirt.dll which is found in
the
system32 directory.
