09-22-2005 12:48 PM
09-23-2005 02:44 PM
09-26-2005 12:57 PM
09-26-2005 02:05 PM
Hi Brian,
We are currently working on resolving this issue for a future version of TestStand. The behavior of Perforce has changed between versions of Perforce. We were incorrectly storing information (that used to be ignored by Perforce) inside the workspace file, rather than a local configuration file. To temporarily get around this problem, you can open the workspace file inside of a text editor, such as notepad, and remove the following line:
SccDbName = "....."
This will allow you to open the file. However, when you add this file back to Perforce, you will see the same problem. We are working to fix this in a future version of TestStand.
Allen P.
TestStand R&D
09-26-2005 03:15 PM
09-26-2005 03:29 PM
