03-19-2024 02:19 PM
Hi
I'm trying to get where the Configure -> Station Options -> Execution default values are but no joy. My goal is to change the default value from feature "On Run-Time Error" to "Ignore".
I looked every file on C:\ProgramData\National Instruments\TestStand 2019 (32-bit)\Cfg.
Using 2019 32-bits (19.0.0.170)
03-21-2024 02:08 AM
https://www.ni.com/docs/de-DE/bundle/teststand/page/configuration-files.html
gives you a pretty comprehensive overwiew about which configuration files are used by TestStand.
Have you checked GeneralEngine.cfg ?
03-25-2024 11:35 PM
Hello Oli
Yes I checked GeneralEngine.cfg (as suggested by the config files doc), but the only tags that I "found" regarding this feature were BreakOnStepFailure and BreakOnSequenceFailure bellow InteractiveBranchMode tag (which is the option above the On Run-Time Error feature in Station Options)
But, as On Run-Time Error is a select feature, I'm not 100% sure that these tags targets the select option because both BreakOnStepFailure and BreakOnSequenceFailure have a Bool classname. I was expecting something like InteractiveBranchMode tag that has a Num classname and accepts a range of numbers as value (I think these numbers represents the indexes of the select options)
Are you aware of this?
Thanks for the feedback!
03-25-2024 11:38 PM
Ok, when writing this, I just checked, which cfg file had changed after I did the mod in SeqEdit
Couldn't you just do a diff on the config files before and after the mod to see what has changed on file level?
03-27-2024 12:21 PM
An alternative and a preferred method is to use the API (StationOptions.RTEOption - NI). Is that not an option?
Anand Jain
NI
