NI TestStand
Specify Relative Report Path
I would like to set the directory of my report to be a relative path from where my sequence file resides using a callback. For example "..\\..\\Reports" Can anybody point me in the right direction?
(2,237 Views)
RunState.SequenceFile.Path + "\\..\\..\\Reports"
Check these out:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8FPSA0
http://www.ni.com/example/26634/en/
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,207 Views)
Select "Specify Report File path by expression" and Frame the expression in such a way that relative path is build.
(2,192 Views)
