05-15-2014 11:39 AM
I am starting to play around with the TestStand API and I have questions about how to configure a TSAdp.LabViewModule.
I am using a couple examples from NI and the developer community to get started:
http://www.ni.com/example/30263/en/
https://decibel.ni.com/content/docs/DOC-18401
These examples work as I expect and I understand them. I am struggling with how to specify the VI parameter values in the module when the step type is "Action." In other words, how do I set these parameters?
All of the examples I see use step types that have fields defined, which are accessible through the API with "AsPropertyObject." The Action type, by default, only has the Result field.
Can I set the parameter values of a VI with the TestSTand API? If so, how?
Jacob
05-16-2014 04:08 PM
Well, I figured it out on my own so I'd figure I'd share the solution:
