08-12-2021 10:27 AM
I would like to implement custom error handling using SequenceFilePostStepRuntimeError
engine callback.
I also use SequenceFilePostResultListEntry
engine callback to filter some results. When the error occurs in SequenceFilePostResultListEntry
, SequenceFilePostStepRuntimeError
callback does not trigger.
Why is that? Can't engine callback trigger another callback?
Example in the attachment (start with A.seq).
08-12-2021 10:36 AM - edited 08-12-2021 10:46 AM
Nevermind. I found the answer (as always after I post...)
TestStand calls other Engine callbacks only when executing the SequenceFileLoad or SequenceFileUnload Engine callbacks. TestStand does not call Engine callbacks when executing the other Engine callbacks.
This is lame IMO ☹️
