05-10-2018 02:06 PM
I cannot save a sequence to the %TestStandPublic% folder.
I am logged into Windows as Administrator, and logged into TestStand as admin.
I can create edit/delete/save whatever file from Windows Explorer (e.g Word Notepad Copy Paste works fine) in %TestStandPublic%, however I cannot Save a new sequence file or update an existing sequence file from the TestStand Editor to that location.
NI TestStand 2016 32 bits.
Windows 10.
I am stuck, and would be grateful for any help you can provide.
Rollin
Solved! Go to Solution.
05-11-2018 10:35 AM
Hi Rollin,
Can you try following the steps in this KB to see if they solve your issue?
http://digital.ni.com/public.nsf/allkb/4BD2F16C6D9BA8E5862576640000CDE6?OpenDocument
05-11-2018 01:16 PM
Hi Adena,
Thank for that link. I tried that solution but it unfortunately it did not fix my issue.
I implemented a work-around: I deployed LabVIEW 2017 and TestStand 2016 to a Windows7 computer I have and it's all working just fine there. I think my Windows10 Laptop may need to be re-imaged. Anyway my problem is solved. Thank you!
05-11-2018 02:22 PM
Hi Rollin,
I'm glad you're up and running on the Windows 7 computer! This sounds like a Windows admin privileges issue on the Windows 10 laptop. When you go to launch TestStand can you try right clicking and selecting "Run as administrator"?
05-12-2018 07:27 AM
Tried right-clicking and selecting "Run as administrator" >> Issue remains.
