NI TestStand
SeqEdit.exe /setCurrentDir strange behavior
I'm experimenting with SeqEdit.exe CLI. I found /setCurrentDir potentially useful. According to the documentation:
/setCurrentDir instructs the application to set the current directory to the first directory in the File dialog box directory history list, as shown in the following example:
The current directory is the directory the File dialog box initially displays when you open or save a file. Use this option to instruct the File dialog box to display the directory the File dialog box displayed the last time you ran the application. TestStand sets the current directory after processing the other command-line options.
I have run a couple of tests and it seems that directory history is set to the current directory only if I trigger an error.
I have two bat scripts: WithoutError.bat and WithError.bat:
REM "WithoutError.bat"
@ECHO OFF
START "Teststand" "%TestStandBin%\SeqEdit.exe" /setCurrentDir
REM "WithError.bat"
@ECHO OFF
START "Teststand" "%TestStandBin%\SeqEdit.exe" /setCurrentDir "C:\A\B"
I run them from C:\ and from C:\A\B. Here are the results of my experiments:
C:\>C:\A\B\WithoutError.bat
No Error
Directory History: C:\Users\micha\Desktop
C:\>C:\A\B\WithError.bat
Error: Unrecognized command line argument 'C:\A\B'
C:\A\B>WithoutError.bat
No Error
C:\A\B>WithError.bat
Directory History: C:\A\B
As you can see, the directory history is correct only if I have an error.
Is this a bug?
Michał Bieńkowski
CLA, CTA
Someone devote his time to help solve your problem? Appreciate it and give kudos. Problem solved? Accept as a solution so that others can find it faster in the future.
Make a contribution to the development of TestStand - vote on TestStand Idea Exchange.
Message 1 of 1
(212 Views)
