Root Class C# .NET namespace and class aren't showing up in this box after dll is entered in the Assembly section in Test Stand
I entered the .dll file successfully into Test Stand. I am trying to add a .net sequence into test stand and I am unable to access the class in test stand in the Root class section and in the .NET Invocation section.
I'm using the default C Sharp file as a test and I'm using C# Visual Studio 2022 .NET 6.0 the C# Class is attached below. I don't know what I am doing wrong. I'm really stuck on this I would appreciate any help on this problem. Thanks
(430 Views)
TestStand does not support .NET Core (5.0,6.0,7.0). IT uses .NET Framework. That's likely your reason.
Their roadmap shows support for it coming in a future version, but as far as I know it has not happened yet, and they haven't said the specific version it will be.
(376 Views)
