Remove step info from TestStand report
Hello all,
I want to remove the step info or merge it into loop indices (highlighted in image), It increases the steps in report. Please help.
(864 Views)
If I understand the problem, disabling results recording option for this step should work for you. See https://zone.ni.com/reference/en-XX/help/370052AA-01/tsref/infotopics/db_step_prop_run_opt_tab/
Alternatively you can always try to tweak the result list.
Michał Bieńkowski
CLA, CTA
Someone devote his time to help solve your problem? Appreciate it and give kudos. Problem solved? Accept as a solution so that others can find it faster in the future.
Make a contribution to the development of TestStand - vote on TestStand Idea Exchange.
(680 Views)
