06-09-2020 04:04 AM
Hi!
I am using TestStand 2019 f2 (19.0.0.170 32 bit), python 3.7 on Windows10.
I am traying to call a tkinter GUI app in python with operation type Call Method.
I get the following:
<class 'IndexError'>
list index out of rangeCall Stack information:
File "c:\users\?\teststand\test-stand-base\teststand\python code modules\monitor\source\monitor.py", line 80, in test_stand_entry
root = tk.Tk()
File "C:\Users\?\AppData\Local\Programs\Python\Python37-32\Lib\tkinter\__init__.py", line 2018, in __init__
baseName = os.path.basename(sys.argv[0])IndexError: list index out of range
The sys.argv[0] should be the script file full path, and is not set by testStand for some reason. My Adapter settings are:
Python Interpreter: Global, without any virtual env.
Best regards
06-12-2020 11:29 AM - edited 06-12-2020 11:33 AM
07-14-2021 04:51 AM
Did you find an answer for this? I have the exact same issue.
I call a python action step. have a simple hello world function that I call where I also print out the sys.argv[0] but the list is empty where I'm expecting the script name.
07-15-2021 07:08 AM
sys.argv in python represents command line arguments.
Python sets the sys.argv[0] to the python path only when you execute your script from an executable like python.exe. When you use python.exe, you specify the path of the script as a command line argument and hence in that scenario, sys.argv[0] will contain the path of the script.
If you use Python in REPL mode, it will set the sys.argv[0] to be empty string. Then, when you import your file and call the same function, you might have undesired behavior if any code assumes that sys.argv[0] contains the path of the file being executed.
Calling a python function from TestStand is like importing the specified module and executing the specified function. There is no command line argument involved. Hence there will not be sys.argv[0].
As a workaround, when TestStand calls your module, you can set sys.argv[0] and then continue the operation. This is the same workaround you need to when when you import the module in a python REPL and execute the function.
-Shashidhar
07-15-2021 08:03 AM
Thank you for your reply.
We have 4 different installations of TestStand and there is only one that does not set the sys.argv, all others return the sys.argv[0] as an empty string. Some modules like tinker are complaining there is no value in sys.argv[0].
I would rather not update all my scripts to update sys.argv[0], however, I found an issue documented and the fix forces python to have something in the sys.argv https://bugs.python.org/issue32573
The fix is implemented in 3.8 and installing 3.8 fixes the issue for us but I want to avoid having multiple version of python for deployments.
How would TestStand enable REPL mode or have an empty string in sys.argv[0]?
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
