Property loader and translator
Hi all,
I'm using a translator to convert xlsx to seq format. And it's working perfectly.
But I'm trying to use Property loader feature. When I launch the tool, I get an error( see below the call stack)
The property loader calls "CanTranslate" function of my translator (ExcelTranslator.dll) by passing argument file name : "C:\Program Files (x86)\National Instruments\TestStand 2019\Components\PropertyLoader\DocumentFormat.OpenXml.dll"
My translator returns False because it can't translate this file.
So the property loader generates an exception
So, do I have to modify my translator, or is it a bug in TS?
Thanks for your help
An exception occurred inside the call to .NET member 'LaunchImportExportTool':
System.Runtime.InteropServices.COMException (0xFFFFBD34): An error occurred attempting to translate the file 'C:\Program Files (x86)\National Instruments\TestStand 2019\Components\PropertyLoader\DocumentFormat.OpenXml.dll' to a TestStand Sequence File.
The 'CanTranslate' callback in 'C:\Users\Public\Documents\National Instruments\TestStand 2019 (32-bit)\Components\Translators\ExcelTranslator.dll' returned the following error:
This file's format is not supported or you don't specify a correct format.
à NationalInstruments.TestStand.Interop.API.FileInformation.get_IsDotNetAssembly()
à NationalInstruments.TestStand.PropertyLoader.ManagedPluginDiscoverer.GetPluginModulesInDirectory(String directory)
à NationalInstruments.TestStand.PropertyLoader.PluginModules.RePopulatePlugins()
à NationalInstruments.TestStand.PropertyLoader.EntryPointsForStepSettingsPane.GetPluginsInformation(SequenceContext sequenceContext, Boolean forcePluginDiscover)
à NationalInstruments.TestStand.PropertyLoader.ImportExportTool.ImportExportTool..ctor(Engine engine, SequenceFile selectedSequenceFile, Sequence selectedSequence)
à NationalInstruments.TestStand.PropertyLoader.ImportExportTool.ImportExportTool.LaunchImportExportTool(SequenceContext context, SequenceFile selectedSequenceFile, Sequence selectedSequence)
(793 Views)
Can you post your implementation for "CanTranslate" API from ytour translator plugin?
If your implementation looks something like this,
try {
    *translationIndex = 0;
     return 1;
catch(...)
try to change it to check for the specific extension that you support. So something like:
try {
    if (std::string(extension) == std::string("xlsx ")) {
        return  1;
return 0;
catch(...)
Hope this helps,
Anand Jain
NI
(761 Views)
Accepted by topic author maxmont
I 've found my mistake.
I returned an error as string description.
In fact, NI recommand not returning an error just 0 as status.
(755 Views)
