Ni.com is currently experiencing issues that may cause some pages to fail.
Support teams are actively working on the resolution.
09-08-2005 11:04 AM
09-13-2005 11:24 AM
09-20-2005 07:15 AM
I have tried to decrease the priority level of the "SeqEdit.exe" processus in the Windows device Manager, but the problem is still present !
I have tried to completely reinstall TS3.0, but the problem is still present !
What should I do exept completely reinstall my Laptop ?
Emmanuel.B
09-21-2005 09:52 AM - edited 09-21-2005 09:52 AM
Emmanuel -
There was a behavior that we worked around in TestStand where a video driver caused the sequence editor to repeatedly receive Windows messages. Each time the sequence editor processed the message, another one was generated by the driver. This issue was discovered in 2003 with TestStand 3.0 and it was fixed in TestStand 3.1. I do not know if this is the same problem that you are seeing but it probably is.
The problem surfaced after the customer updated their driver using Microsoft's update utility. The driver that exhibited the problem was NVIDIA GeForce4 MX 420. The customer was able to workaround the problem by disabling the nView Desktop Manager in the NVIDIA nVIEW video driver utility.
Hope this helps...
Message Edited by Scott Richardson on 09-21-2005 09:53 AM
09-22-2005 12:12 PM
