Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
03-05-2024 01:45 PM
I have created a simple LabVIEW UI that runs a TestStand sequence and displays the sequence in an Execution View while it is running. Is it possible to display a preview of the sequence prior to execution?
03-05-2024 04:10 PM
I think I have found most of a solution here: Display the Sequence Steps of A TestStand Sequence in LabVIEW
It doesn't seem to be able work with both the Execution View as used for execution and preview.
Thanks!
We'll be in touch soon!
