NI TestStand
NI teststand creat string into array
i want to creat a string into array in test stand using CVI
TS_PropertySetValString (seqContextAsPropObj, &errorInfo, "FileGlobals.Data.Measure[0].Value", TS_PropOption_InsertElement, "NOK");
firstly the array not existe and when i use the function above i see in test stand just FileGlobals.Data.Measure created but the Value not created
how i can do this ?
(1,280 Views)
I think I am confused by your ask. Do you want to turn a string into an array of characters?
Chase
NI Technical Support Engineer
(1,253 Views)
maybe i am worng, because your screenshot shows not all.
Your variable "Measure" is a container instead an array. So will never access  with this lookup string
best regards
Juergen
--Signature--
NIWeek 2017: Standardized HIL Test Automation With TestStand
NIWeek 2016: Capturing ATE Requirements With Requirements Gateway
Feedback or kudos are welcome
(1,248 Views)
