NI Teststand 2012 will not launch after installing 2014
Hi all,
I installed 2014 on a machine that had 2012 on it. Since then, I cannot launch 2012 with out this error (see picture attached)
I am using the version selector and when I enable 2014 it launches fine.
I have the correct .NET Framework installed and have tried uninstalling 2012/2014 and reinstalling to no avail.
Has anyone seen this issue before?
L
(1,853 Views)
Basically NI Supports Multiple Versions (In case of LabVIEW), But not used Different Versions of TS in same machine.
Make sure whether you are calling 32bit/64bit.
பழனிவேல் திருவெங்கடம்
(1,846 Views)
Hi Palanivel,
Both versions of  Teststand are 32bit.
I thought the version selector allows you to use either version?
Thank you.
(1,843 Views)
Yes Ofcourse it should allow the user to select available TS versions (with Selected bit).
(1,840 Views)
Still not working,
Any other ideas?
(1,838 Views)
Whether both versions of TS are displayed in Version Selector Window?
If yes can you able to Make Active?
(1,835 Views)
Both versions are available in the version selector, yes.
I am able to make either 2012/2014 active. When I launch 2014 (32bit) 2014 will launch successfully.
However, when I launch 2012 (32bit) the error (as per the screenshot above) displays and I cannot open 2012.
(1,833 Views)
