10-14-2015 09:58 AM
The above NI is in one of the Baggage scanner which I service and maintain-Rapiscan systems.Recently it showed an Error:FAILED TO INITIALIZE.DATAIO MODULE.
I have tried all the possible tests to no avail.please assist.
10-16-2015 02:17 AM
I think you may have posted this in the wrong forum, unless you baggage scanner runs TestStand, which is highly unlikely.
If the system has been running for a long time and suddenly gives this error, it is most likely a hardware error. Maybe PCI Express card in the PC has jumped out of its socket or is has just suffered a defect. I could also be the PC which has suffered a defect. I hope this helps.
Cheers
Jens.
09-12-2021 11:54 PM
I have same problem,till moment i did not get solve,can you help me ,i am maintenance in rapiscan system
09-13-2021 08:23 AM
If there were no OS or Software Updates that led to this failure, I would consider it as a hardware failure and replace the board.
Before doing the replacement, try moving this DAQ to another system and see if it works there, if it does not then it is a failed card.
09-16-2021 01:31 PM
Hello freinds ,i have problem on rapiscan x ray machinescreen ,there are lines on picture ,i cleaned Adc and x ray generator .x ray machine was in stors for 2 month
09-17-2021 11:42 AM
And did you try changing the monitor?
