Loop a Test Sequence For Validation of the Test, not the part
I would like to run our main sequence continuously on a single part, in order to look for random errors/failures in the test sequence (or maybe the part too).
That is, I'd like to just have the entire sequence run through, produce a report, and then start again.  Obviously we would need to disable the SN and any other dialogs.
I considered creating a "Test loop the sequence" sequence, but wouldn't that only produce one report?
(280 Views)
in your report setting select this option:
then it will produce a report file for every iteration.
Roman
(244 Views)
Thanks Roman, but I think I wasn't clear.  I want to *test the test*, so I want to run the entire test !100X, and have it produce a report each time.
We have some instabilities, and we want to see how often they will occur.  I'd rather not have to sit there and enter the SN every 6 minutes, so I was hoping there was some way to loop the entire test process.
(233 Views)
TestStand and User Interfaces can be called from the command prompt and thus you could set up a "batch" script to call the sequence over and over again.
In your sequence add a PreUUT callback and bypass the prompt and also hardcode the UUT SerialNumber and PartNumber
Here's an example(this assumes that seqedit is on the path):
start /wait seqedit.exe /quit /runEntryPoint "Single Pass" "C:\pathtomysequence\mytest.seq" /outputToStdIO & call echo %^errorlevel%
/quit will close the Sequence Editor each time.  If you don't want that then use /useExisting
start /wait seqedit.exe /useExisting /runEntryPoint "Single Pass" "C:\pathtomysequence\mytest.seq" /outputToStdIO & call echo %^errorlevel%
"& call echo %^errorlevel%"  will echo the Test Status "Exit Code" result to the standard output and if useful you can redirect that to a log file.
See: https://zone.ni.com/reference/en-XX/help/370052AA-01/tsuiref/reftopics/applicationmgr_exitcode_p/
Edited: added /wait argument forgot /runEntryPoint in second example
(231 Views)
Awesome, I will give that a shot!
(227 Views)
Jed,
here i attached a client sequence that makes your Sequential model run UUT loop FileGlobals.NumRuns times without dialogs.
I hope this helps.
Roman
(221 Views)
Note: I updated my post above with some corrections, hope it helps
(215 Views)
