Is it possible to create a UInt16 (Custom Data Types) in TS?
I am a newbie in TestStand, someone knows if it is possible to create a UInt16 custom Data Types?
I try to go in:
View --> Types --> Custom Data Types --> Right click to insert Type -->  ...and then?
This need sorts cause I have a .NET invocation that returns a UInt16 type and I would save this result in a variable for reusing it in TS (such as for other invocations).
PS. I have not LABVIEW.
Thank you
(2,279 Views)
Accepted by NicoGare
as you can read in the helpTestStand stored all numeric values, including integers, in a double-precision, floating-point format.
Thus, you cannot create a custom data type or a numeric variable of type UInt16 since only 64-bit representation is available. If you right-click your custom numeric data type or your local numeric variable, you can select a representation between Float64, Int64, UInt64.
I hope this helps!
Bye
Licia
(2,231 Views)
Thank you,
I found Object Reference as a solution.
(2,213 Views)
