06-13-2017 06:20 AM
when running a testplan then there was at the beginning a visible window with the testplan and you could see where the testplan currently executes. Also with the results, limits and PassedFailed.
But now i dont know what happenend. The Tracing is enabled in Configure+StationOptions+[X]Enable Tracing, but still nothing is shown in the execution window.
What is missing?
Thx
06-13-2017 06:52 AM - edited 06-13-2017 06:53 AM
Which version of TS are you running? Which UI are you using? What is the process model?
You can set Execution.TracingDisabled in TS steps to disable/re-enable tracing for specific sections of your test. Maybe you have such a step included which disables tracing but you missed to have a second step later re-enabling it.
