NI TestStand
How to include preUUTloop results in report?
In preUUTloop the operator is polled to choose a few parameters (messages with 2-3 buttons to choose from)
How do I record his choces in the report?
Desirably, this data should be reported in the very beginning on the report only, not in every UUT loop.
TS3.5
Thank you!
Message Edited by fomine on 08-25-2008 09:13 PM
-fomine
_________________________________
You can do greater things with LabVIEW!
(2,063 Views)
Take a look at this example.
I have attached it to every uut just to demonstrate how it works
I your case i would also override the ModifyReportHeader Callback and add it Report header
wich is a little bit of work.
Greetings
juergen
--Signature--
NIWeek 2017: Standardized HIL Test Automation With TestStand
NIWeek 2016: Capturing ATE Requirements With Requirements Gateway
Feedback or kudos are welcome
(2,043 Views)
Hello Fomine,
We have a Developer Zone that I believe fits your needs here. I found this by searching "add extra results to report" at ni.com
As a side note, this is extremely easy in TestStand 4.1 (as seen by the help here). Could I have a sales representative contact you about upgrading? If so just let me know (don't post your information) and I will get your email and get in touch with you.
edit: Beaten by juergen with example code too! Thanks juergen you are truly appreciated!
Message Edited by Dr. Doiron on 08-27-2008 01:40 AM
With warm regards,
David D.
(2,042 Views)
Hi j_dodek,
Thank you for your help!
I implemented it similarly, for now, but what I really needed is the Modifying HTML Report Headers to Include Custom Information. Thanks for pointing me in the right direction. I will get back if I cannot make it work.
Hi Dr. Doiron
Thank you, interesting method is there, even though not what I needed.
-fomine
(1,990 Views)
