06-12-2012 11:38 AM
I am working on creating custom stylesheets for TestStand reports. I am doing this by allowing the user to select the Additional Results from each step that she wants to see in the report in a LabVIEW edit substep. I can read the names of each step like in the attached image, but I'm having trouble accessing their (children?), the additional results.
06-12-2012 12:13 PM
You can try GetFormattedValue after GetPropertyObjectByOffset. GetFormattedValue will get a number as a String.
If the type of property is known then use GetValNumber, GetValString and GetValBoolean for numeric, string and boolean respectively.
06-12-2012 12:45 PM
I think I figured it out, I guess I hadn't tried everything. The solution is something like the attached. Thanks for the suggestion!
