You will need to use the Run Engine Installation Wizard found on the Tools menu. In addition you need to create a installation set for the operator interface.
Look at Chapter 16 Distrubuting TestStand ( chapter 17 for version 2).
Once you have created your installation, install is on your new system.
The serial number etc is part of the process model. When you run the entry point 'Test UUTs' the PreUUT callback is executed which asks the user for the serial number.
Hope this helps
Ray Farmer
Ray Farmer
