07-09-2007 02:37 AM
07-09-2007 03:37 AM
Hi Andras.
I have the same problem and now I'm waiting for an answer from technical support.
I will post it as soon as possible.
Regards.
07-09-2007 07:24 AM
01-18-2008 04:20 AM
Thanks for your post.
Actually the tech support answer worked for me...But under certain condition.
If your Wait step has the record result enabled, then you get everything (including the wait result). However, if you disable the record on that step, then the behaviour is different and you don't get anything :(.
So a new question...Is it possible to get the result in the report without the wait stated?
Matthieu
01-18-2008 04:43 AM
03-18-2022 04:37 AM
Actually it is the exactly the step "Wait for Thread" that passes the results from the sub sequence to the main sequence. This step must be included in the result recording for the subsequence result to be passed to the main sequence and then to the report.
In fact all other steps could have "Recording disabled" either by a common sequence setting or by individually setting the "Result Recording Option"=Disabled for each step.
I usually disable record resulting for all steps in all sequences using the Sequence Properties setting "Disable Result Recording for All Steps" and then enable only those steps I want in the report using the step setting "Result Recording Option"="Enabled (Override sequence setting)".
