03-29-2017 01:54 AM - edited 03-29-2017 01:55 AM
Hello Everyone,
Firstly, I would thank NI for having such a great community to interact with LabVIEW experts and Professionals.
I am developing a double pulse signal using NI 9402 4-Channel, 50 ns, LV TTL Digital Input/Output Modulealong with NI cDAQ-9181, CompactDAQ-Chassis. The problem I face is that, I can generate the double pulse but the waveform which I get in LabVIEW and the waveform I get in Oscilloscope are different (I mean the Timeperiod).
For example, I would like to generate Double pulse at times (T0, T1, T2, T3) and T0 say 100ms and T1 should be (T1=T0+T1), (T2=T0+T1+T2) and (T3=T0+T1+T2+T3). The waveforms what I see in oscilloscope are "T0" will start at zero(0) and T1 will be 100ms and T2 will be (T2=T0+T1).
How to get the timings exactly like in Labview..? I am also attaching the VI and screen shots of Oscilloscope, Please find them in the attachments.
In the photos the "T0" is given as 150ms...don't bother
I thank one and all for your support.
04-05-2017 01:23 AM
Hello Harikrishna125,
starting and stopping the task takes some time, do all in one waveform.
06-26-2017 03:59 AM
Hi Glasner,
Thank you for the reply and the code works as expected.
