Ni.com is currently experiencing issues that may cause some pages to fail.
Support teams are actively working on the resolution.
Error Code: -17601 "Attempted to load a module for a step whose module has not yet been specified"
I am trying to run my first Test Stand sequence, and am getting the following Error: "Error Code: -17601, Attempted to load a module for a step whose module has not yet been specified".
I have specified the correct module under the Test Stand "Action" properties, and am pointing to the right vi. I am not sure why it is giving me this error.
(3,889 Views)
Hi Shoab,
So when you right click on your step and select Specify Module.... The Edit LabVIEW VI dialog will appear, in the VI Pathname control is your VI and under that control appear the full path to your VI, if it contains "(No File Specified)" then thats your problem. You will need to use the file browse control to find your VI.
Regards
Ray Farmer
Regards
Ray Farmer
(3,886 Views)
