01-10-2006 03:23 PM
01-11-2006 01:10 AM
Short answer, yes.
When you create your step type, for the Specify Module you would use a SequcenceCall Adapter instead of your labview adapter.
You would have to have your sequencefile with your sequences already created seperately and you would set the sequencefile not to use a process model in the sequencefile properties.
Regards
Ray Farmer
01-11-2006 08:03 AM
Great!
Only problem is: I don't see any "Sequence Call Adapter". I am looking on the General tab of the Custom Step Type Properties, under "Designate an Adapter". Sequence Call is not an option. (I am using TS3.5)
When I select "None", which was my other guess, then the "Specify Module" button disappears.
How exactly do I set it up?
01-11-2006 09:35 AM
10 Things,
The reason you do not see the sequence call adapter is because it is hidden by default.
Go to Configure->Adapters and uncheck the 'Hidden' check box for the sequence call adapter.
Regards
Antonio Lie
01-11-2006 02:14 PM
08-05-2021 06:36 AM - edited 08-05-2021 06:37 AM
The answer from Antonio Lie above should be marked as the answer/resolution to the question
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
