04-23-2018 06:33 AM
Hello community,
From time to time it would be nice to indent a given step in the report. I could surround it with a for loop or so, but I am wondering if there is a more elegant way to do it?
thanks.
04-24-2018 05:56 PM
Are you just looking to customize the appearance of the report? Let us know exactly what you want so the community can provide some possible solutions.
Michael B.
Applications Engineer
04-25-2018 03:11 AM
Hey Michael,
If I have a step in a for loop executing lets say 5 times, then it appears in the report 5 times and all these 5 entries are indented. The more nested loops I have the more indentation I get in the report for a given step.
In the sequence I work on at this moment I dont use any nesting, but for some tests it would be nice if they would show up in the report indented. It would increase the readibility of the report a lot.
Is there a way to programatically achieve this, or do I really need to put a for loop around the step? This latter solution would be pointless in the sense that it makes my sequnce look more complicated than it is really.
Thanks.
04-25-2018 10:16 AM
The easiest way to improve readability of your reports is to change the style sheet in the Report Options window. Navigate to Configure » Result Processing to launch the Report Options dialog, then select the Options icon for the Report Generation plug-in. Then select the Style Sheet dropdown and select either tr5_expand.xsl or tr5_report.xsl. Both of these report styles are more readable.
Michael B.
04-25-2018 12:27 PM
To figure out how to add the indents in the report can you answer the following questions:
Michael B.
04-26-2018 01:18 AM
I'm using the built-in "expand.xsl" stylesheet to generate my xml reports.
As I have described above, I'm looking for a way to indent some of my steps programatically.
thx.
04-26-2018 11:52 AM
It looks like to implement the functionality you desire you will need to modify the stylesheet. Here are some resources to help you out:
How to Modify a TestStand XML Report Header
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAIBSA4
Customizing XML Report Style Sheets
There are still other options that can be explored to make your reports more readable. Some examples could be creating a summary report, removing non essential information from the report, or modifying the background cell color based on the step.
Michael B.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
