From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
Break execution after custom run-time error handler callback
I am using Teststand 2010 SP1 and have written a custom runtime error handler based on the ErrorHandlerExample example that ships with TestStand. It has been implemented as a StationPostStepRuntimeError callback in my Station Callbacks folder.  I have modified the example as follows:
(1) Added code to turn off the UUT transmitter if it was on.
(2) Added a call to an executable that sends an email to the currently logged in user.
(3) Calls the standard TestStand run-time error dialog using the Engine DisplayRunTimeErrorDialog method.
(4) Processes the user's selection, then turns on the UUT transmitter for any option other then Abort.
The callback also checks the status of the Break and "Don't Show again for this execution" options selected by the user.  If the user selects Break then the only option I can find is to call the API Execution.Break() method which breaks the execution right there in my callback. The user then has to single step there way out of the callback.   Is there a way of instructing TestStand to complete the callback execution and break immediately after completing the callback (i.e.at the step following the error)?  I've zipped up and attached my modified sequence.
Alternatively, is there a better way of doing this?
David
(3,442 Views)
Accepted by David_Jackson
Didn't have a chance to try it yet but maybe StepOut is your solution?
From the TS Help:
StepOut Method
Syntax
Execution.StepOut
Purpose
Resumes the execution from a suspended state and then suspends the execution again after execution of the current sequence completes.
jigg
CTA, CLA
testeract.com
(3,439 Views)
Thanks jigg.  That works just fine for me.Smiley Happy
David
(3,432 Views)
