11-09-2021 04:47 AM
Hello everybody,
i´m trying to login a user programmatically during the MainForm_load of the Simple Userinterface.
I tried already
axApplicationMgr.GetEngine.CurrentUser = axApplicationMgr.GetEngine.GetUser(current_user)
but this only changes the user which appear in the login window.
Is it possible to start the login process without showing those login window?
Thanks for advice.
11-19-2021 02:23 PM
The login prompt is handled by the FrontEndCallBacks sequence. You can change the behavior by following this article
11-22-2021 10:32 PM
You can also use this method if it suits your application ;
Ravi
11-23-2021 11:34 PM
Thank you, ee-jallen, for the link for the article. This solution is not exact what i was looking for but i will try to modifie it to login a specified user.
If i am able to find a solution, i will post it here later.
11-23-2021 11:38 PM
Thank you for your advice RaviShrigiri, but our TestSystem will only have one Windows Account for all the user, so this solution don´t work for me.
11-29-2021 04:13 AM
Okay... The problem was caused, because the EXE-Call parameters were processed after the MainForm_Load, so my current_user variable was still empty.
I set the
now in the axApplicationMgr_ProcessUserCommandLineArguments(...) function and it works.
Thanks for your help.
