Hi Marc,
can you explain a bit more what you're trying to acheive. Is this a custom step type, or is it one of the built in Numeric Limit check steps? (which matches the Status Expression you've given).
Can you post the offending sequence here?
Do other steps like this one work? Does this sequence / step work on another machine?
Using the above status expression on a non numeric limit step produces error 17306 where it tells you that it's looking for DataSource which doesn't exist.
I can't see why the "." in the step name could cause a problem. What happens if you simplify the expression (temporarily), i.e. set it to "Passed" or "Failed", and then work up from there?
Are you evaluating something under the DataSource of the step which could be causing a problem?
I get error 17320 if I try to put a bad item un the DataSource e.g. Test()
What is your Step.DataSource set to?
Sacha
// it takes almost no time to rate an answer
