NI Package Management
Build a Package using LabVIEW 20xx
This document is part of the NI Package Management Portal.
  1. Make sure you have support for the Package build specification installed.
    • LabVIEW 2018: Already includes Package build specification by default
    • LabVIEW 2014-2017: You need to install LabVIEW Package Builder through NI Package Manager
      • Install NI Package Manager, if not already installed.
      • Launch NI Package Manager, and install LabVIEW Package Builder.
  2. Follow the instructions in the Creating Packages with the LabVIEW Package Build Specification tutorial.
Comments
andre.buurman@carya
on
When will the help instruction be improved, it feels like an executive summary. There's lot's of questions that remain unanswered, in special package dependencies and caveats.
André (CLA, CLED)
mahmoud2432
on
I'm having troubles with the communication with the picoscope. When I use the labview files that are in the intalation cd. When I run for example the file "PicoScope5000ExampleBlock.vi" labview is not able to recognize the picospcope. I also noticed that my computer (I also tried in other computers) do not recognize the picoscope as an usb component. Then I can not use neither the "Measurement and automation Explorer" of labview.
Schliepe
on
Looks like the link is no longer valid.  Any change the link could get corrected?
joerg.hampel
Active Participant Active Participant
on
Where can I find the "LabVIEW Package Builder" now that NIPM doesn't support browsing anymore?
DQMH® (The Future of Team-Based LabVIEW Development)
joerg.hampel
on
With the help of some LabVIEW friends (thanks, @jono and @dataflow_g), I was able to figure out that installing NI Package Manager 20.5 will bring back the search feature, and I was eventually able to install LabVIEW Package Builder.
crossrulz
Knight of NI Knight of NI
Knight of NI
on
Or wait a couple of months for the next version of NIPM.
https://forums.ni.com/t5/NI-Package-Manager-NIPM/Browse-Products-tab-gone-after-update/m-p/4118453/h...
GCentral
Mathieu_R.
on
I was looking for a way to install LabVIEW Package builder for LabVIEW 2017, before the next release of NIPM that should reintroduce the "browse product" functionnality.
And I get it. Here is how I did it.
Using a computer running NIPM 20.1, I was able to find the package and install it (using the browse product). Then, I picked a look into nipkg.ini file, located in %ProgramData%\National Instruments\NI Package Manager\Settings. It contains feed information. The two following sections are the ones I was looking for :
[nipkg.repo.ni-package-builder-labview-support-1-0-released]
configurable=true
enabled=true
name=ni-package-builder-labview-support-1-0-released
ni-managed=true
uri=https://download.ni.com/support/nipkg/products/ni-package-builder-labview-support/1.0/released
[nipkg.repo.ni-package-builder-labview-support-1-0-released-critical]
configurable=true
enabled=true
name=ni-package-builder-labview-support-1-0-released-critical
ni-managed=true
update-service-severity=critical
uri=https://download.ni.com/support/nipkg/products/ni-package-builder-labview-support/1.0/released-critical
So, on the target computer (running NIPM 20.6) add these two sections into nipkg.ini (copy/paste).
Then run NIPM. If not already activated, click on the settings wheel and enable the option Display available packages and feed managing tools (in french fo me, just trying to figure the name in english - see screenshot below): 
You can then check in Feed that ni-package-builder-labview-support-1-0-released and ni-package-builder-labview-support-1-0-released-critical are listed:
Then click on Package tab, and you should see NI Package Building Support for LabVIEW:
...and you should finally be able to install it:
Hope this helps,
Contributors
