04-13-2016 10:41 AM
I would like to take control of my cRIO 9030 through VNC.
Does anybody already did that ?
Christophe
04-14-2016 09:18 AM
I did that at some point quite a bit back, not sure if it was something with the actual packages available on the repo or something one-off that I did. It seems that there's not really anything installable from the feeds.
As such, you basically have three options going forward:
I personally would recommend either of the first two options
05-25-2016 01:02 AM
Finally I found a solution. I installed RealVNC on the cRio-9030.
I used VNC for Linux.Generic installer 64 bits.
It works perfectly.
06-07-2016 05:21 AM
Hello Christophe.
Could you please write what exactly I have to do to install VNC on cRIO? I have downloaded VNC-5.3.1-Linux-x64-ANY.tar.gz archive on my computer, but I'm not sure how I can install it on cRIO and setup the connection after all.
I'd appreciate any help. Thanks in advance.
07-08-2016 03:10 AM
svpug
Try the steps in the attached document.
07-12-2016 03:50 AM
