From 11:00 PM CST Friday, Feb 14th - 6:30 PM CST Saturday, Feb 15th, ni.com will undergo system upgrades that may result in temporary service interruption.
07-21-2014 04:07 PM
Hi All
Just a quick question for some advice. You can restart the cRio from the FPGA but, if your FPGA is suffering from issues this doesn't necessarily work. This is a bit of an issue of you want a watchdog component to a program which has a last resort 'restart and hope for the best' option.
In C++ is there a way you would recommend restarting a cRio running real time OS without using the FPGA- there's lots of options out there so I wonder if there is best a best practice approach or just go for any linux based option?
Cheers
07-21-2014 06:20 PM
If we are talking about C/C++ and the resulting application is being run by root/admin (e.g. it is started by an initscript), simply call system("reboot") (there are RT ramifications for using system() but considering you're rebooting, no big deal). You can also call reboot() but keep in mind that this will not call the shutdown initscripts and instead just reboots right away.
If this is from within a LVRT program, there is the Watchdog API that you can use to provide all of the functionality you're looking for without the need to implement everything yourself (a thread to act as watchdog, a means of thradsafe communication with the watchdog thread to "pet" it, etc.)
07-22-2014 08:56 AM
If it is LV there is a restart VI in the sys config API as well.
If you just want to restart your application instead of the entire controller I've been using a trick where a bash file is continuously ensuring the application is running and if it stops it restarts the application. That way if the watchdog trips the exe just has to stop running and then the bash restarts it. Something like:
#!/bin/bash
while !(./myProg.exe) do sleep 1 echo "Restarting program..." done
The command is your exe. Although I haven't tried it I have thought about doing something fancy where depending on the return code the bash does something different. In C you do that with the main() return code. In LabVIEW you can't do that (I think), but you could write to a file and the bash read it.
07-22-2014 10:21 AM
Thanks Both.
Really helpful answers. Somewhat related, is there any way to access the User1 LED (not the FPGA LED) in C++? Looks easy in LabView but can't find any documentation on how the LED might be accessed if programming in another language?
07-22-2014 10:27 AM
Funny enough...yes. I just figured it out.
const char* LED_ON = "255\n";
const char* LED_OFF = "0\n";
FILE *LED = NULL;
LED = fopen("/sys/class/leds/nizynqcpld:status:red/brightness","w");
while(1)
if (i%2 == 0)
fwrite(LED_OFF,sizeof(char),2,LED);
else
fwrite(LED_ON,sizeof(char),4,LED);
fflush(LED);
sleep(1);
i++;
fclose(LED);
07-23-2014 11:23 AM
Cheers Brian!
I would not have figured that out myself.
