NI Linux Real-Time Discussions
Issue in mounting NFS share on compactRio-9068
I am trying to mount a nfs share on compactRio-9068 with "mount -t nfs" command but it fails with message: "Connection refused" . Details about the nfs server are as follows:
Linux host "eeiash" running nfs server is running with 64-bit CentOS Linux (Ip Addr: 192.146.3.20).  nfs exports on this server are:
[root@eeiash]# cat /etc/exports
/tmp localhost(rw,sync) 192.146.3.0/24(rw,sync,no_root_squash) 10.35.13.0/24(rw,sync,no_root_squash) *(ro,sync)
I could see that /tmp share is exported from server side
[root@eeiash]# showmount -e
Export list for eeiash:
/tmp                 (everyone)
rpcInfo on server host is as follows. Everything sems okay on server side.
[root@eeiash]# rpcinfo -p
   program vers proto   port
    100000    2   tcp    111  portmapper
    100000    2   udp    111  portmapper
    100024    1   udp    905  status
    100024    1   tcp    908  status
    100011    1   udp   1000  rquotad
    100011    2   udp   1000  rquotad
    100011    1   tcp   1003  rquotad
    100011    2   tcp   1003  rquotad
    100003    2   udp   2049  nfs
    100003    3   udp   2049  nfs
    100021    1   udp  33001  nlockmgr
    100021    3   udp  33001  nlockmgr
    100021    4   udp  33001  nlockmgr
    100003    2   tcp   2049  nfs
    100003    3   tcp   2049  nfs
    100021    1   tcp  44065  nlockmgr
    100021    3   tcp  44065  nlockmgr
    100021    4   tcp  44065  nlockmgr
    100005    1   udp   1015  mountd
    100005    1   tcp   1018  mountd
    100005    2   udp   1015  mountd
    100005    2   tcp   1018  mountd
    100005    3   udp   1015  mountd
    100005    3   tcp   1018  mountd
When tried to mount /tmp share on compactRio-9068 (Ip Addr: 192.146.3.60)
admin@compactRio-9068:# mount -t nfs 192.146.3.20:/tmp /mnt/iasHome
mount: mounting 192.146.3.20:/tmp on /mnt/iasHome failed: Connection refused
I also tried "-v" option with mount command but seems like busybox "mount" on compactRio does not recongnize "-v" option does not provide any details information about failure.
Later, I checked /var/log/messages on server side (on eeiash)
Jul  2 15:31:12 nas mountd[22463]: authenticated mount request from 192.146.3.60:846 for /tmp (/tmp)It appears
It appears that server has authinticated the request from compactRio client but somehow compactRio fails to establish connection with nfs share and display the error message. I also tried to mount this share on another linux based host which worked fine. Not sure if compactRio needs any additional settings/packages.
Has somebody come across similar issue in past? How do I debug it?
WillsG
Message 1 of 14
(10,195 Views)
WillsG,
What login are you logged in as?  Are you trying to do this from an SSH prompt, or via the System Exec.vi?  Can you supply the exact command you are using?
-TD
Message 2 of 14
(7,575 Views)
WillsG, welcome!
Can you check to see if there are some NFS utilities that are available that are not currently installed on the target through opkg? Uncomment the feed addresses in /etc/opkg/angstrom-*-feed.conf files (and change the URL to point away from us.feeds.angstrom-distribution.org as that mirror went down, point it to just feeds.angstrom-distribution.org. Sorry if it's not exact, working from memory here), then run the following
opkg update
opkg list | grep -i nfs
Message 3 of 14
(7,575 Views)
Hi TD,
I am logged in to compactRio as admin (root user with uid=0). I am performing this mount operation from ssh prompt. Here is a list of commands I used:
1. ssh to compactRio (192.146.3.60) as admin  from other linux host
2. Commands used on ssh shell of compactRio:
     # cd /mnt
     # mkdir iasHome
(this commands shows error message: mount: mounting 192.146.3.20:/tmp on /mnt/iasHome failed: Connection refused)
Hi BradM,
I will check about the nfs packages and update on this thread soon.
WillsG
Message 4 of 14
(7,575 Views)
Hi BradM,
I did update the list of packages from opkg repo feed (src/gz angstrom-base http://feeds.angstrom-distribution.org/feeds/next/ipk/eglibc/armv7a/base/).
With "# opkg list | grep -i nfs", I don't see any nfs utilities on updated list. I also tried "opkg list-installed | grep -i nfs" but it returned blank as well.
--WillsG
Message 5 of 14
(7,575 Views)
