07-24-2014 05:54 AM
Hi All
Anyone got any links for a newbie on how to deploy a C/C++ application on the cRio 9068 so it starts when system starts?
I have the development environment sorted out with Eclipse etc. and have an executable on the cRio; just stuck on which files to transfer where to cRio and how to get the application to automatically start when cRio restarts.
Sure this is pretty simple but most of what I can find on google doesn't deal with real time OS.
Thanks for the help
07-24-2014 07:02 AM
jamie_mac, this is precisely part of the presentation that I'm putting together for NIWeek, so it is very, very fresh in my mind!
Basically, anything that is listed as an additional dependency in the Eclipse project needs to be made available on the target. In the case that you have a dependency that you simply downloaded and made it available to the Eclipse project, there's a good chance that you can install the library on your target via opkg.
If the library is not in the feed repository (e.g. you are using a library that you created in Eclipse) you will simply need to also copy that library over to the target and ensure that it is in one of the searched library directories (for user-installed libraries, the old convention is to use /usr/local/lib/, but pragmatically I recommend /usr/lib/) and run ldconfig to have the OS rebuild it's library loading cache.
Check to make sure that you can run the binary directly from a shell. If there are issues, the errors will likely give you some breadcrumbs to follow.
Once you are able to launch the binary from a shell, it is time to write a reasonable sysvinit script. While NI Linux RT is a real-time OS, at heart it is still a traditional Linux distribution. Any of the sysvinit-style how-to's will work for you. Let us know if you run into issues
07-24-2014 07:05 AM
Hi Jamie,
There are probably several ways to do so. Then it will also be different if you are dealing with a RT application or if it is a "standard" one that is (as a matter of fact) embedded in the RT target...
On my side, what I am using so far depends on what I want to deploy :
A- if it is a standalone application without direct connection to a labview application
B- if it is a text based application compiled with gcc that you would like to use within labview
Of course NI guys would probably have better/enhanced ways to do it...
Short answer (that means probably more google search, but it should provide a starting point) :
For A, if you really want autoboot I would suggest that you use the traditional rc scripts and manage your application as a daemon:
-> cross compile your application using eclipse etc
-> upload it in /usr/local/bin (already in $PATH) with scp
-> create a rc rcscript in /etc/script.d refering to your application and create a symbolic link in the appropriate /etc/rcX.d
I haven't try so far to develop something in that way which could have an influence on the rt scheduler at the end but works as expected for the standard use
For B:
You can use an easy (but perhaps stinky) way which is a system exec node from labview to point to your external application
A more appropiate way to my mind would be to convert your application in a shared lib and to use it as a new labview block
-> cross compile your application as a shared library instead of a standalone dev
-> upload it in /usr/local/lib with scp then a traditional ldconfig on it
-> use the call library function node in your labview application
... but you should take into account the determinism of it if your application is RT related and/or if you launched additional threads from it.
Hope it helps!
07-26-2014 05:46 PM
Thanks BradM, now I really feel like an old man 😉
07-27-2014 05:22 PM
The primary reason for my recommendation is due to the fact that LabVIEW won't find libraries tucked into /usr/local/lib unless the soname is unversioned (e.g. libfoo.so instead of libfoo.so.1) and ldconfig is configured to examine /usr/local/lib.
07-27-2014 06:44 PM
You are probably right but as I am really an old man, I always start by looking if /etc/ld.so.conf contains what is requested 😉 Then ldconfig do itself the magic trick of libs unversioning...
Nevertheless, everything is doable ... just a question of habits at the end!
07-30-2014 05:21 AM
Hi s.boria/Brad
Apologies for the late reply and thanks for the advice. Curently working on some other things but will back to cRio soon and try deploying application. Will keep you updated on how that goes.
Cheers
08-04-2014 10:19 AM
Been playing around with this and writing a script in /etc/init.d seems to be the thing to do so thanks s.boria and Brad for pointing me in the right direction. Just discovered this great tutorial added recently.
08-04-2014 01:15 PM
FYI. I posted some issue I'm having getting these scripts to work here as seemed like a more relevent place.
