NI製品ディスカッション
キャンセル
次の結果を表示
次の代わりに検索
もしかして:
RT deployment error NI Scan Engine
Hi, I'm Nori.
I found an error when running RT.
I'm developing RT program using Ethercat NI 9144 on PXI 8108 on LabVIEW8.6
I think all required sacn engine, drivers are installed enough.
It was no issue to connect to the PXI but when I tries to deploy the ethercat master,
error dialog attached below comes out and can't open the VI.
Two c-RIO moduls ,NI9205 AI+-10 and  NI 9213 TC are set into the ethercat chassis.
Could you tell me what driver is required to deploy the ethercat?
I attached the report what software is installed currently on the target.
I'm sorry for the inconvenience, the report is written in Japanese but you could see " software".
Then you
could see what software is installed .
Sincerely,
Nori
softeware configuration
  • NI-PXI8108-2F126F96
      • AMD AM79C972 10/100Mbps Ethernet Driver 1.0.0.3.0
      • Broadcom 57xx Gigabit Ethernet Driver 3.0.0.3.0
      • IndCom for EtherCAT Scan Engine Support 2.0
      • Intel 1000e Ethernet Driver 1.0.0.2.7
      • Intel 8254x Ethernet Driver 3.1.0.3.1
      • Intel 8255x 10/100Mbps Ethernet Driver 3.0.0.3.0
      • LabVIEW Real-Time 8.6.1
        • NI RT Extensions for SMP (MultiCore Support) 10.0
        • Web Server for LabVIEW RT 1.0.1
      • Language Support for LabVIEW RT 1.0.0.3
      • Microsoft Visual Studio 2008 Runtime Support 1.0
      • NI Scan Engine Advanced I/O Access 1.0
      • NI-1394 External Drive Support 1.4.2.3.0
      • NI-DAQmx 9.1.5
        • Multifunction DAQ (E, M, S, X, and SC Express Series)
        • AO SERIES
        • TIO SERIES (Counter Timer)
        • DIGITAL I/O
        • NI-653x
        • Dynamic Signal Acquisition
        • NI-SCXI
        • Switches
      • NI-FGEN 2.6.0
      • NI-RIO 3.5.0
      • NI-SCOPE 3.6.2
      • NI-Serial RT 3.6.0
      • NI-SWITCH 4.0.2
      • NI-Sync 3.2.1
      • NI-VISA 5.0
        • NI-VISA GPIB Passport
        • NI-VISA ENET-ASRL Passport
        • NI-VISA ENET Passport
        • NI-VISA PXI Passport
        • NI-VISA Remote Passport
        • NI-VISA Server 5.0
      • NVIDIA Ethernet Driver 3.0.0.3.2
      • System State Publisher 2.0.0
0 件の賞賛
メッセージ1/1
3,623件の閲覧回数
