Our online shopping is experiencing intermittent service disruptions.
Support teams are actively working on the resolution.
Multisim and Ultiboard
Timer Circuit
I am trying to build a circuit using 4060BP that would generate a 2Hz clock using a 32.768kHz crystal oscillator and then generate a 1Hz clock using 4013BP. However, when I run the circuit the LED does not turn on/off at 2Hz and 1Hz speed and when I check the frequency using an oscilloscope, I measured kilohertz of frequency. I was wondering if someone could help me figure out what is wrong with the circuit. The circuit is attached below.
(757 Views)
Привет! Попробуйте так подключить кварц. А второй делитель сами подключите, важно, что правильная генерация заработала...
(691 Views)
Hello! I tried to run the circuit but I am not getting a 2Hz pulse at PIN 3.
(668 Views)
Я подправил модель кварца, задал начальный заряд индуктора и схема начала выдавать то, что нужно...
А вот с библиотечными параметрами кварца получаем частоту в 1000 раз больше
(607 Views)
